[Qgis-developer] Re: build qgis in Windows - missing GEOS and PROJ.4
Etienne Tourigny etourigny.dev at gmail.com
Sat May 5 10:47:02 PDT 2012
Yes I did install them beforehand, the point is that they were not
detected automatically.
The spatialindex stuff is rather new (I thinks\), so there might need
to be some improvements in the cmake files for Windows.
Same for others which have been around for some time (proj,spatialite,sqlite)
Etienne
On Sat, May 5, 2012 at 2:24 PM, G. Allegri <giohappy at gmail.com> wrote:
> You also need to install those dev libs from osgeo4w. I had to set the proj
> lib path manually.
> I'm out of home, as soon as I'll be back to my pc I can share my notes.
> In the meanwhile I can only confirm that the build procedure for MSVC works
> fine for all the qgis components (also python bindings).
> giovanni
> Inviato da dispositivo mobile
> Il giorno 05/mag/2012 19.06, "Etienne Tourigny" <etourigny.dev at gmail.com> ha
> scritto:
>> Hi,
>> I got it working last night when running form the osgeo4w shell (my
>> mistake), but there were still a number of missing entries which I had
>> to add (which are also installed by osgeo4w)
>> PROJ_LIBRARY-NOTFOUND
>> SPATIALINDEX_INCLUDE_DIR-NOTFOUND
>> SPATIALINDEX_LIBRARY-NOTFOUND
>> SPATIALITE_LIBRARY-NOTFOUND
>> SQLITE3_LIBRARY-NOTFOUND
>> I tried adding LIB_DIR to both the osgeo script and as a CMake entry,
>> to no avail.
>> Thanks
>> Etienne
>> thanks
>> Etienne
>> On Sat, May 5, 2012 at 1:32 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> > Hi
>> > Are you sure you are launching cmake from in an osgeo4w shell? If you
>> > do that everything should *just work*. Also you should be able to set
>> > a LIB_DIR env var and the cmake find rules will look there for libs.
>> > So normally you should not need to tweak much in cmake other than
>> > fixing the paths for gnu utils.
>> > Regards
>> > Tim
>> > On Sat, May 5, 2012 at 3:23 AM, Etienne Tourigny
>> > <etourigny.dev at gmail.com> wrote:
>> >> It seems I had overlooked the osgeo4w /include and /lib directories,
>> >> which contain all the necessary libs.
>> >> However, how can things be setup so that cmake looks for all
>> >> dependencies in the osgeo4w directory, instead of specifying each one
>> >> manually?
>> >> regards,
>> >> Etienne
>> >> On Fri, May 4, 2012 at 3:46 PM, Etienne Tourigny
>> >>> Hi all,
>> >>> following the Windows building instructions at [1] using VS2008
>> >>> Express, cmake complains that I am missing GEOS and PROJ.
>> >>> I get
>> >>> GEOS_INCLUDE_DIR-NOTFOUND
>> >>> GEOS_LIBRARY-NOTFOUND
>> >>> PROJ_INCLUDE_DIR-NOTFOUND
>> >>> The instructions do not say anything about building GEOS and PROJ.4
>> >>> with Visual Studio (but there are instruction for building GEOS with
>> >>> MINGW)...
>> >>> [1]
>> >>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
>> >>> thanks
>> >>> Etienne
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> > Please do not email me off-list with technical
>> > support questions. Using the lists will gain
>> > more exposure for your issues and the knowledge
>> > surrounding your issue will be shared with all.
>> > Visit http://linfiniti.com to find out about:
>> >  * QGIS programming and support services
>> >  * Mapserver and PostGIS based hosting plans
>> >  * FOSS Consulting Services
>> > Skype: timlinux
>> > Irc: timlinux on #qgis at freenode.net
