[Qgis-developer] Re: build qgis in Windows - missing GEOS and
PROJ.4
G. Allegri
giohappy at gmail.com
Sat May 5 10:24:26 PDT 2012
You also need to install those dev libs from osgeo4w. I had to set the proj
lib path manually.
I'm out of home, as soon as I'll be back to my pc I can share my notes.
In the meanwhile I can only confirm that the build procedure for MSVC works
fine for all the qgis components (also python bindings).
giovanni
Inviato da dispositivo mobile
Il giorno 05/mag/2012 19.06, "Etienne Tourigny" <etourigny.dev at gmail.com>
ha scritto:
> Hi,
> I got it working last night when running form the osgeo4w shell (my
> mistake), but there were still a number of missing entries which I had
> to add (which are also installed by osgeo4w)
> PROJ_LIBRARY-NOTFOUND
> SPATIALINDEX_INCLUDE_DIR-NOTFOUND
> SPATIALINDEX_LIBRARY-NOTFOUND
> SPATIALITE_LIBRARY-NOTFOUND
> SQLITE3_LIBRARY-NOTFOUND
> I tried adding LIB_DIR to both the osgeo script and as a CMake entry,
> to no avail.
> Thanks
> Etienne
> thanks
> Etienne
> On Sat, May 5, 2012 at 1:32 PM, Tim Sutton <lists at linfiniti.com> wrote:
> > Hi
> > Are you sure you are launching cmake from in an osgeo4w shell? If you
> > do that everything should *just work*. Also you should be able to set
> > a LIB_DIR env var and the cmake find rules will look there for libs.
> > So normally you should not need to tweak much in cmake other than
> > fixing the paths for gnu utils.
> > Regards
> > Tim
> > On Sat, May 5, 2012 at 3:23 AM, Etienne Tourigny
> > <etourigny.dev at gmail.com> wrote:
> >> It seems I had overlooked the osgeo4w /include and /lib directories,
> >> which contain all the necessary libs.
> >> However, how can things be setup so that cmake looks for all
> >> dependencies in the osgeo4w directory, instead of specifying each one
> >> manually?
> >> regards,
> >> Etienne
> >> On Fri, May 4, 2012 at 3:46 PM, Etienne Tourigny
> >>> Hi all,
> >>> following the Windows building instructions at [1] using VS2008
> >>> Express, cmake complains that I am missing GEOS and PROJ.
> >>> I get
> >>> GEOS_INCLUDE_DIR-NOTFOUND
> >>> GEOS_LIBRARY-NOTFOUND
> >>> PROJ_INCLUDE_DIR-NOTFOUND
> >>> The instructions do not say anything about building GEOS and PROJ.4
> >>> with Visual Studio (but there are instruction for building GEOS with
> >>> MINGW)...
> >>> [1]
> http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
> >>> thanks
> >>> Etienne
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> > Please do not email me off-list with technical
> > support questions. Using the lists will gain
> > more exposure for your issues and the knowledge
> > surrounding your issue will be shared with all.
> > Visit http://linfiniti.com to find out about:
> > * QGIS programming and support services
> > * Mapserver and PostGIS based hosting plans
> > * FOSS Consulting Services
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120505/0bc2e5c2/attachment.html
