[Qgis-developer] crash on close without layer
Paolo Cavallini
cavallini at faunalia.it
Mon May 7 23:05:13 PDT 2012
Hi all.
If I close qgis before having added a layer, I get a segfault:
warning: Can't read pathname for load map: Errore di input/output.
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/bin/qgis.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f33380216cc in QAction::setEnabled(bool) () from
/usr/lib/libQtGui.so.4
Anyone confirms? Worth reporting?
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
