[Qgis-developer] This had escaped me!
Etienne Tourigny
etourigny.dev at gmail.com
Wed May 9 07:43:35 PDT 2012
On Wed, May 9, 2012 at 11:40 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Il giorno mer, 09/05/2012 alle 14.41 +0100, Giovanni Manghi ha scritto:
>> Thanks, it works.
>> I just noticed that today the only way to add a zipped shape is through
>> the browser and the add vector layer dialog, drag and drop and CLI all
>> return "is not a valid or recognized data source". If is a zipped raster
>> all methods work fine.
>> Can you confirm?
>> cheers
> Hi Giovanni,
> here drag&drop it in MapCanvas works fine!
> but only with zipped files containing a single dataset!
> Before it was not so! I could choose which dataset import from a popup
> window!
> What is changed?
Hmm you could drag&drop a zip file before? and before what? Was
this possible before my changes or you mean before yesterday's
changes?
regards
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt
