[Qgis-developer] Using group by to set a PostGIS datasource using
QGIS Python API
Ian Packham
i.packham at ucd.ie
Thu May 10 01:56:52 PDT 2012
Hi
I asked the following question at gis.stackexchange.com, but had no luck so far. Can any of you guys help?
Ian
http://gis.stackexchange.com/questions/24941/using-group-by-to-set-a-postgis-datasource-using-qgis-python-api
I am writing a QGIS Plugin and wish to obtain data from a PostGIS table using the Group By clause using something like the following code:
uri = QgsDataSourceURI()
uri.setConnection('localhost', '5432', 'postgis', 'postgres', 'xxx')
Query="select param_id, st_union(the_geom) as the_geom from myTable group by param_id"
uri.setDataSource('', '(%s)' % postGisQuery, "the_geom",'','gid')
vlayer1 = QgsVectorLayer(uri.uri(), 'testlayer1', "postgres")
This gives the error "No key field for query given." because it is looking for the gid key field. But if gid was put in the select statement of the Query, we won't get aggregated rows, just distinct rows. If I try an aggregation function on gid, I get the same error. If I try aliasing the aggregate, I get an "Erroneous query" error (even count(gid) as gid), same as if I put 'param_id' as the key field in setDataSource, because 'param_id' is not a primary key, I guess.
In this case, forcing the key field in the uri seems to make the group by clause useless. Is there another workaround I haven't thought of or is this the expected behaviour?
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120510/8075de3a/attachment.html
