[Qgis-developer] Using group by to set a PostGIS datasource using
QGIS Python API
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu May 10 02:04:52 PDT 2012
Hi Ian,
I am always using views for such things. I am not sure (never tried) if
you can use a subselect as table parameter for uri.setDataSource.
So I would create a view on the DB. Be sure, that the id field of the
view is defined as the pk in its source table (no combined pk) and that
the values in the id field are unique.
Bernhard
Am 10.05.2012 10:56, schrieb Ian Packham:
> Hi
> I asked the following question at gis.stackexchange.com, but had no luck
> so far. Can any of you guys help?
> Ian
> http://gis.stackexchange.com/questions/24941/using-group-by-to-set-a-postgis-datasource-using-qgis-python-api
> I am writing a QGIS Plugin and wish to obtain data from a PostGIS table
> using the Group By clause using something like the following code:
> |uri= QgsDataSourceURI()
> uri.setConnection('localhost', '5432', 'postgis', 'postgres', 'xxx')
> Query="select param_id, st_union(the_geom) as the_geom from myTable group by param_id"
> uri.setDataSource('', '(%s)' % postGisQuery, "the_geom",'','gid')
> vlayer1= QgsVectorLayer(uri.uri(), 'testlayer1', "postgres")
> This gives the error "No key field for query given." because it is
> looking for the gid key field. But if gid was put in the select
> statement of the Query, we won't get aggregated rows, just distinct
> rows. If I try an aggregation function on gid, I get the same error. If
> I try aliasing the aggregate, I get an "Erroneous query" error (even
> |count(gid) as gid|), same as if I put 'param_id' as the key field in
> setDataSource, because 'param_id' is not a primary key, I guess.
> In this case, forcing the key field in the uri seems to make the group
> by clause useless. Is there another workaround I haven't thought of or
> is this the expected behaviour?
> Qgis-developer mailing list
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
