[Qgis-developer] Re: possible bug? Spatialite rule-based render
Koos Hagg
hagg.koos at gmail.com
Thu May 10 22:07:52 PDT 2012
> Hello all,
>> I follow the dev mailing list but have not yet had a good reason to write
>> to it. Now maybe I do!
> I'm working with some OSM data (from Geofabrik). I downloaded the latest
>> Shapefiles with them, and also created a Spatialite db from those (by
>> drag-and-drop in the awesome QGIS browser).
>> Rule based rendering is working fine for the point and polygon layers in
>> the db, but the spatialite table/layer 'roads' (linestring) crashes QGIS as
>> soon as I try to load a rule based style for it.
>> Single, Categorized, and Graduated style rendering are working.
>> Spatialite reports that the geometry is good and that the spatial index is
>> fine. Also, the 'waterways' layer (also a linestring) is working fine...
>> I'm using QGIS 1.8.0-9, WIndows 7 64bit, but this also happens in 1.7.4.
>> Can anybody duplicate this?
>> Thanks for any help!
>> Koos
>> ps-- this is the message that pops up along with "QGIS has stopped
>> working..."-- but I'm not sure what it all means...
>> Problem signature:
>> Problem Event Name: APPCRASH
>> Application Name: qgis.exe
>> Application Version: 0.0.0.0
>> Application Timestamp: 4fac4c80
>> Fault Module Name: QtCore4.dll
>> Fault Module Version: 4.7.1.0
>> Fault Module Timestamp: 4d530715
>> Exception Code: c0000005
>> Exception Offset: 000025bf
>> OS Version: 6.1.7601.2.1.0.256.48
>> Locale ID: 1033
>> Additional Information 1: 0a9e
>> Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
>> Additional Information 3: 0a9e
>> Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120511/dd4d160b/attachment.html
