[Qgis-developer] Re: possible bug? Spatialite rule-based render
Nathan Woodrow madmanwoo at gmail.com
Thu May 10 22:15:06 PDT 2012
Hi Koos,
Are you able to provide the Spatialite db that is having the issues, and
the style file.  This way we can test it to see what's up.
Regards,
Nathan
On Fri, May 11, 2012 at 3:07 PM, Koos Hagg <hagg.koos at gmail.com> wrote:
> Hello all,
>>> I follow the dev mailing list but have not yet had a good reason to
>>> write to it. Now maybe I do!
>> I'm working with some OSM data (from Geofabrik). I downloaded the latest
>>> Shapefiles with them, and also created a Spatialite db from those (by
>>> drag-and-drop in the awesome QGIS browser).
>>> Rule based rendering is working fine for the point and polygon layers in
>>> the db, but the spatialite table/layer 'roads' (linestring) crashes QGIS as
>>> soon as I try to load a rule based style for it.
>>> Single, Categorized, and Graduated style rendering are working.
>>> Spatialite reports that the geometry is good and that the spatial index is
>>> fine. Also, the 'waterways' layer (also a linestring) is working fine...
>>> I'm using QGIS 1.8.0-9, WIndows 7 64bit, but this also happens in 1.7.4.
>>> Can anybody duplicate this?
>>> Thanks for any help!
>>> *Koos*
>>> ps-- this is the message that pops up along with "QGIS has stopped
>>> working..."-- but I'm not sure what it all means...
>>> Problem signature:
>>>   Problem Event Name:    APPCRASH
>>>   Application Name:    qgis.exe
>>>   Application Version:    0.0.0.0
>>>   Application Timestamp:    4fac4c80
>>>   Fault Module Name:    QtCore4.dll
>>>   Fault Module Version:    4.7.1.0
>>>   Fault Module Timestamp:    4d530715
>>>   Exception Code:    c0000005
>>>   Exception Offset:    000025bf
>>>   OS Version:    6.1.7601.2.1.0.256.48
>>>   Locale ID:    1033
>>>   Additional Information 1:    0a9e
>>>   Additional Information 2:    0a9e372d3b4ad19135b953a78882e789
>>>   Additional Information 3:    0a9e
>>>   Additional Information 4:    0a9e372d3b4ad19135b953a78882e789
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120511/591f8518/attachment-0001.html
