[Qgis-developer] Fwd: Threads in sextante
kimaidou
kimaidou at gmail.com
Mon May 14 00:16:26 PDT 2012
Hi all
+1 for using QProcess. I am using it in Lizmap Plugin to run external
librairies (winSCP on windows, lftp on linux), and it works great. You can
easily connect signals like readyReadStandardOutput(),
readyReadStandardError() and finished(int, QProcess::ExitStatus) to your
plugin methods.
Michael
2012/5/13 Etienne Tourigny <etourigny.dev at gmail.com>
> Victor,
> I agree on all your points.
> May I suggest to have a unique interface/approach that other existing
> interfaces can benefit from (i.e. standalone gdaltools and ftools).
> It seems that QProcess is an interesting candidate (and QThread when
> not using external app.), because it works in both c++ and in pyqt
> (ref. gdaltools) - plus there is already code inside qgis that uses
> it.
> my 2 centavos
> Etienne
> On Sun, May 13, 2012 at 6:13 PM, Victor Olaya <volayaf at gmail.com> wrote:
> > Here is my opinion on all that, in short:
> > -The main idea of using threads is not now to execute multiplep
> > algorithms at the same time, so we can remove a lot of complexity
> > (like 2 processes writing the same file, as it was mentioned)
> > -Implementing a canceling mechanism is going to be the greatest
> > improvement once we have the threading stuff
> > -So, for me, this is what should be done:
> > 1)implementing the threading part
> > 2) implement the cancelling mechanism (a responsive cancel button, etc)
> > 3) modifying algorithm to respond to cancellin events.
> > I think that would be more than enough for a first part, and it would
> > be a great improvement for SEXTANTE
> > Regards
> > p.s. Just to let you know, I am leaving for Honduras tomorrow, and
> > will be there working for 2 weeks, so I not might be very active on
> > the lists during the next 15 days or so
> > 2012/5/13 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> >> Hi Alex
> >>>Also I think about rewritting fTools in C++ and integrating its
> >>>algorithms into QGIS
> >>>analysis library. This makes tools a bit faster and will allow to use
> >>>algorithms in
> >>>plugins
> >> That would be a great enhancement and leverage the analysis library as a
> >> whole.
> >> Regards,
> >> Marco
> >> On 13.05.2012 09:23, Alexander Bruy wrote:
> >>> Hi Etienne,
> >>> 2012/5/12 Etienne Tourigny<etourigny.dev at gmail.com>:
> >>>> I stand corrected then - I guess I was confusing it with ftools, which
> >>>> is blocking and does not spawn a process.
> >>>> Any way ftools could be adapted to use the same approach as gdaltools?
> >>> most fTools functions already implemented as threaded, but there are
> some
> >>> minor issues. I work on improving processes handing in fTools, and
> several
> >>> tools already don't block main QGIS window, has non-modal dialogs and
> >>> allows
> >>> to cancel running process.
> >>> algorithms in
> >>> plugins
> >> Dr. Marco Hugentobler
> >> Sourcepole - Linux& Open Source Solutions
> >> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> >> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> >> Technical Advisor QGIS Project Steering Committee
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120514/f18a7a0e/attachment.html
