[Qgis-developer] Re: show grid on map canvas (similiar to grid
used in composer) - strategy?
Larry Shaffer
larrys at dakotacarto.com
Mon May 14 10:48:35 PDT 2012
Hi John,
On Mon, May 14, 2012 at 5:43 AM, John Donovan <mersey.viking at gmail.com>wrote:
> On 13 May 2012 22:49, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
> > Basically I think there could be 2 concurrent and complementary ways
> > to implement grids:
> > 1) basic grid in core, similar to what is already in the composer map
> > (and in my branch)
> > 2) more refined grid(s) as plugin/vector layers, whose rendering order
> > can be fine-tuned
> Nice work Etienne! Over the weekend, I've knocked up a little plugin
> of the second type - a plugin layer that uses the new symbology
> system.
> It's marked as experimental, and there are a few things on the TODO
> list, but it can be found in my plugin repo:
> http://109.123.122.13/qgis/plugins.xml
> One of the todo's is saving the styling information - I can't find
> where I can get the XML of the symbol for my writeXml() function. Any
> ideas?
I tried your Grid Overlay plugin and this is what I found.
Same error as Etienne reported:
File "/home/tourigny/.qgis/python/
plugins/grid_overlay/gridpluginlayer.py",
line 63, in draw
self.symbol.renderPolyline(polyline, renderContext)
it also occurs when I cancel the dialog. The plugin layer is made
regardless of cancelling dialog on initial plugin launch.
When I click the 'Set Style...' button I get this error:
File
"/Users/larrys/.qgis/python/plugins/grid_overlay/gridpropertiesdialog.py",
line 42, in chooseStyle
self, False)
TypeError: QgsSymbolV2SelectorDialog(QgsSymbolV2, QgsStyleV2,
QgsVectorLayer, QWidget parent=None, bool embedded=False): argument 3 has
unexpected type 'GridPropertiesDialog'
Is that not implemented yet?
I noticed in your metadata.txt and __init__.py you assigned the Layers
category, but the action doesn't show up there. Does it need to use the
following to be added to/removed from the Layer menu? (worked when I edited
gridoverlay.py):
self.iface.insertAddLayerAction(self.action_newGrid)
self.iface.removeAddLayerAction(self.action_newGrid)
Tested with QGIS 1.8 rev.69ef4de on Mac 10.6.8.
Looking forward to using your plugin on the current map I am working with.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120514/31e27ffe/attachment.html
