[Qgis-developer] Re: show grid on map canvas (similiar to grid
used in composer) - strategy?
John Donovan
mersey.viking at gmail.com
Mon May 14 12:36:00 PDT 2012
Hi Larry and Etienne,
Thanks for being brave!
On 14 May 2012 18:48, Larry Shaffer <larrys at dakotacarto.com> wrote:
> I tried your Grid Overlay plugin and this is what I found.
> Same error as Etienne reported:
> Traceback (most recent call last):
> File "/home/tourigny/.qgis/python/
> plugins/grid_overlay/gridpluginlayer.py",
> line 63, in draw
> self.symbol.renderPolyline(polyline, renderContext)
That's odd, I'm using 1.7.4 and Python 2.7.2, but I can't imagine the
API to have changed. It runs fine on both my Linux and Windows boxes.
Looking at the C++ docs, indeed RenderPolyline() takes a QgsFeature as
the second parameter, so I'm not sure why it should work for me!
> it also occurs when I cancel the dialog. The plugin layer is made regardless
> of cancelling dialog on initial plugin launch.
Mea culpa.
> When I click the 'Set Style...' button I get this error:
> File
> "/Users/larrys/.qgis/python/plugins/grid_overlay/gridpropertiesdialog.py",
> line 42, in chooseStyle
> self, False)
> TypeError: QgsSymbolV2SelectorDialog(QgsSymbolV2, QgsStyleV2,
> QgsVectorLayer, QWidget parent=None, bool embedded=False): argument 3 has
> unexpected type 'GridPropertiesDialog'
> Is that not implemented yet?
Another odd one. GridPropertiesDialog, the class in which this
function is defined, is inherited from QtGui.QDialog, so should make a
valid parent to the symbol selector dialog. I've set it to None on my
machine with no ill effects.
> I noticed in your metadata.txt and __init__.py you assigned the Layers
> category, but the action doesn't show up there. Does it need to use the
> following to be added to/removed from the Layer menu? (worked when I edited
> gridoverlay.py):
> self.iface.insertAddLayerAction(self.action_newGrid)
> self.iface.removeAddLayerAction(self.action_newGrid)
Ah yes, a copy-and-paste code bug. Ahem...
> Tested with QGIS 1.8 rev.69ef4de on Mac 10.6.8.
> Looking forward to using your plugin on the current map I am working with.
I'm glad to hear others will be using it, when it works.
Regards,
John
One of the advantages of being disorderly is that one is constantly
making exciting discoveries. - AA Milne
