[Qgis-developer] Trying to build qgis in Win
Anibal Alarcon
anibal.alarcon at gmail.com
Mon May 14 14:04:20 PDT 2012
Hello, I'm trying to build qgis in my virtualized WinXP (with a little
change in a simple marker) and have one question and one problem... The
batch with the enviroment that both has the VC++ and the OSGeo4W variables
leave in blank PYTHONPATH is correct? And when I run the batch I get : The
system can not find the path specified
(_path=C:\OSGeo4W\apps\Python27\Scripts)...
I change in python.bat the line: set
_path=SGEO4W_ROOT%\apps\Python27\Tools\Scripts because this exist but I get
the same.
Do not know if these steps are OK
I continued to cmake-gui, configure and generate and no problem. Then in vc
load (from my build) the qgis1.8.0.sln and Build... How I know if this is
OK? Then the next step is not clear for my. I must close the proyect and
open Install target (which is the file?) and build? ...
That's why I like both Debian...
any idea...
Thanks
Anibal
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120514/11e16bad/attachment.html
