[Qgis-developer] Shape to shapeZ
G. Allegri
giohappy at gmail.com
Wed May 23 04:11:34 PDT 2012
I don't know if it's possible with Qgis API, AFAIK it isn't possible
because Qgis doesn't support Z vaues.
You could consider ogr2ogr, setting -nlt to POINT25D (or POLYGON25D,
etc.) and -zfield to the field from which to peak the Z value.
You can also do it from Qgis vector tools.
giovanni
2012/5/23 francescoboccacci at libero.it <francescoboccacci at libero.it>:
> Hi all,
> a question about convert function.
> I'd like to convert a simple shapefile with z field. I'd like to convert that
> shapefile into shapefileZ.
> Is there a way to do that?
> Thanks
> Francesco
> Qgis-developer mailing list
