[Qgis-developer] help on Sextante Grass description file
(v.to.rast.txt)
Pietro Rossin
pierigis at gmail.com
Wed May 23 04:26:43 PDT 2012
Hi all
I have problems in using the v.to.rast module in Qgis1.8-Sextante.
When I open the module there are:
-Input (required)
-use (many options available)
-column (auto fills on vector selection)
-value (unique value to use if "val" is selected under use)
-output
If I want to make a rasterization based on a value I must select "val" in
use and set a value in value, but I get an error sayng that I must not
specify a column to use
GRASS_INFO_ERROR(3460,1): Column parameter cannot be combined with use of
value option
GRASS_INFO_END(3460,1)
So
I tried to change the v.to.rast.txt description file setting "true" after
the column parameter (i.e. optional)
v.to.rast
v.to.rast
Vector (v.*)
ParameterVector|input|input|-1|False
ParameterSelection|use|use|attr;cat;val;z;dir
ParameterTableField|column|column|input|True
ParameterString|value|value|1
OutputRaster|output|output
After that the column parameter still auto fills in the module form and I
cannot rasterize by a value (if not coded in a column)
How can I solve this?
Thnx
Pietro
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120523/fcc7e892/attachment.html
