R: Re: [Qgis-developer] Shape to shapeZ
francescoboccacci at libero.it francescoboccacci at libero.it
Wed May 23 04:38:42 PDT 2012
Thanks,
Francesco
>----Messaggio originale----
>Da: giohappy at gmail.com
>Data: 23/05/2012 13.11
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>Cc: <qgis-developer at lists.osgeo.org>
>Ogg: Re: [Qgis-developer] Shape to shapeZ
>I don't know if it's possible with Qgis API, AFAIK it isn't possible
>because Qgis doesn't support Z vaues.
>You could consider ogr2ogr, setting -nlt to POINT25D (or POLYGON25D,
>etc.) and -zfield to the field from which to peak the Z value.
>You can also do it from Qgis vector tools.
>giovanni
>2012/5/23 francescoboccacci at libero.it <francescoboccacci at libero.it>:
>> Hi all,
>> a question about convert function.
>> I'd like to convert a simple shapefile with z field. I'd like to convert
that
>> shapefile into shapefileZ.
>> Is there a way to do that?
>> Thanks
>> Francesco
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
