[Qgis-developer] QGIS Server 1.8: empty map with VERSION=1.3.0
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu May 24 08:10:23 PDT 2012
Hi Bernhard
If you switch the x/y coordinates, you also get an image with 1.3. In
some cases, the coordinats are switched in 1.3 (usually geographical
systems). Not a good idea, but that's what the 1.3 spec says...
Regards,
Marco
Am 24.05.2012 16:30, schrieb Bernhard Ströbl:
> Dear all,
> another issue: QGIS Server is responding with an all-white map to a
> GetMap when VERSION=1.3.0 is requested. Map is rendered correctly when
> requesting VERSION=1.1.1
> example:
> http://map2.jena.de/wms/test?LAYERS=rule-based%20style&FORMAT=image%2Fpng&DPI=96&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A31468&BBOX=4459734.0425532,5639372.3404255,4481265.9574468,5646627.6595745&WIDTH=1012&HEIGHT=341
> => white map, replace the version-parameter and you get a map!
> QGIS 1.8 RC 1 (code version c367a35) on OpenSUSE 12.1
> Bernhard
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
