[Qgis-developer] Library linking problems when release changes -
eg. 1.9 --> 1.8
Andreas Neumann
a.neumann at carto.net
Fri May 25 00:24:48 PDT 2012
Whenever there is a change in the major version of QGIS, e.g. 1.7 to
1.9 and most recently the switch back from 1.9 to 1.8 I am running into
problems.
The compile runs fine but when I try to start it I get this message:
error while loading shared libraries: libqgis_core.so.1.8.0: cannot
open shared object file: No such file or directory
But the libqgis_core.so.1.8.0 is present in /usr/local/lib
I removed the build directory and ran ccmake .. and cmake .. again, but
it doesn't solve this problem that it can't find the library that
obviously is present and recent on my machine.
I would very much appreciate if someone could help me out here.
Thanks a lot,
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
