AW: [Qgis-developer] Library linking problems when release changes - eg. 1.9 --> 1.8
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Fri May 25 00:30:13 PDT 2012
Hi Andi
I solved it by exporting LD_LIBRARY_PATH:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
It's a bit strange since I think it used to work without this....
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
> bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
> Gesendet: Freitag, 25. Mai 2012 09:25
> An: qgis-developer
> Betreff: [Qgis-developer] Library linking problems when release changes - eg. 1.9 -->
> 1.8
>  Hi,
>  Whenever there is a change in the major version of QGIS, e.g. 1.7 to
>  1.9 and most recently the switch back from 1.9 to 1.8 I am running into  problems.
>  The compile runs fine but when I try to start it I get this message:
>  error while loading shared libraries: libqgis_core.so.1.8.0: cannot  open shared object
> file: No such file or directory
>  But the libqgis_core.so.1.8.0 is present in /usr/local/lib
>  I removed the build directory and ran ccmake .. and cmake .. again, but
>  it doesn't solve this problem that it can't find the library that
>  obviously is present and recent on my machine.
>  I would very much appreciate if someone could help me out here.
>  Thanks a lot,
>  Andreas
>  Andreas Neumann
>  Böschacherstrasse 10A
>  8624 Grüt (Gossau ZH)
>  Switzerland
> Qgis-developer mailing list
