AW: [Qgis-developer] Library linking problems when release changes - eg. 1.9 --> 1.8
Andreas Neumann
a.neumann at carto.net
Fri May 25 00:38:18 PDT 2012
Thanks Stefan and Kimaidou
Setting LD_LIBRARY_PATH seems to work. It is strange. I was assuming
that /usr/local/lib was searched by default anyway. After all this is
the directory for libraries (next to /usr/lib )
Well - always some mysteries we can't understand ...
Thanks for helping me to solve the problem,
Andreas
On Fri, 25 May 2012 07:30:13 +0000, Ziegler Stefan wrote:
> Hi Andi
> I solved it by exporting LD_LIBRARY_PATH:
> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
> It's a bit strange since I think it used to work without this....
> Regards
> Stefan
>> -----Ursprüngliche Nachricht-----
>> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
>> bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
>> Gesendet: Freitag, 25. Mai 2012 09:25
>> An: qgis-developer
>> Betreff: [Qgis-developer] Library linking problems when release
>> 1.8
>> Hi,
>> Whenever there is a change in the major version of QGIS, e.g. 1.7
>> to
>> 1.9 and most recently the switch back from 1.9 to 1.8 I am running
>> into problems.
>> The compile runs fine but when I try to start it I get this
>> message:
>> error while loading shared libraries: libqgis_core.so.1.8.0: cannot
>> open shared object
>> file: No such file or directory
>> But the libqgis_core.so.1.8.0 is present in /usr/local/lib
>> I removed the build directory and ran ccmake .. and cmake .. again,
>> but
>> it doesn't solve this problem that it can't find the library that
>> obviously is present and recent on my machine.
>> I would very much appreciate if someone could help me out here.
>> Thanks a lot,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
Switzerland
