AW: [Qgis-developer] Library linking problems when release
changes - eg. 1.9 --> 1.8
Matthias Kuhn
matthias.kuhn at gmx.ch
Sat May 26 02:30:10 PDT 2012
To my understanding, the folder /usr/local is to be used for locally
compiled programs and is therefore not set by default by distributions.
That qgis is installed into this folder is defined by
CMAKE_INSTALL_PREFIX which defaults to /usr/local but can easily be
replaced with /usr so it will work without changing the default path. If
you are releasing a package, that's the way to go.
On your development machine you might want to run a stock version of
qgis and a self-compiled one, so you don't want to install the second
ont into /usr as well. In this case you can either export
LD_LIBRARY_PATH (include in .bash_profile to set it automatically) or
you can add the path it in /etc/ld.so.conf (add a file
to /etc/ld.so.conf.d if supported by your distro).
Regards,
Matthias
On Fri, 2012-05-25 at 09:38 +0200, Andreas Neumann wrote:
> Thanks Stefan and Kimaidou
> Setting LD_LIBRARY_PATH seems to work. It is strange. I was assuming
> that /usr/local/lib was searched by default anyway. After all this is
> the directory for libraries (next to /usr/lib )
> Well - always some mysteries we can't understand ...
> Thanks for helping me to solve the problem,
> Andreas
> On Fri, 25 May 2012 07:30:13 +0000, Ziegler Stefan wrote:
> > Hi Andi
> > I solved it by exporting LD_LIBRARY_PATH:
> > export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
> > It's a bit strange since I think it used to work without this....
> > Regards
> > Stefan
> >> -----Ursprüngliche Nachricht-----
> >> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
> >> bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
> >> Gesendet: Freitag, 25. Mai 2012 09:25
> >> An: qgis-developer
> >> Betreff: [Qgis-developer] Library linking problems when release
> >> 1.8
> >> Hi,
> >> Whenever there is a change in the major version of QGIS, e.g. 1.7
> >> to
> >> 1.9 and most recently the switch back from 1.9 to 1.8 I am running
> >> into problems.
> >> The compile runs fine but when I try to start it I get this
> >> message:
> >> error while loading shared libraries: libqgis_core.so.1.8.0: cannot
> >> open shared object
> >> file: No such file or directory
> >> But the libqgis_core.so.1.8.0 is present in /usr/local/lib
> >> I removed the build directory and ran ccmake .. and cmake .. again,
> >> but
> >> it doesn't solve this problem that it can't find the library that
> >> obviously is present and recent on my machine.
> >> I would very much appreciate if someone could help me out here.
> >> Thanks a lot,
> >> Andreas
> >> Andreas Neumann
> >> Böschacherstrasse 10A
> >> 8624 Grüt (Gossau ZH)
> >> Switzerland
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
