[Qgis-developer] Library linking problems when release changes - eg. 1.9 --> 1.8
Andreas Neumann
a.neumann at carto.net
Mon May 28 21:23:03 PDT 2012
Hi Matthias,
Thank you for explaining the reasoning behind this behavior. I can
understand it. The only thing that surprised me is that with older
Ubuntu and/or QGIS version it worked without setting /etc/ld.so.conf or
LD_LIBRARY_PATH - so probably there was some change recently in Ubuntu,
enforcing to actually set /usr/local/lib to be included in the library
path whereas in the past it worked out of the box.
Anyway - it is fine now.
Thanks again to all!
Andreas
Am 26.05.2012 11:30, schrieb Matthias Kuhn:
> Hi,
> To my understanding, the folder /usr/local is to be used for locally
> compiled programs and is therefore not set by default by distributions.
> That qgis is installed into this folder is defined by
> CMAKE_INSTALL_PREFIX which defaults to /usr/local but can easily be
> replaced with /usr so it will work without changing the default path. If
> you are releasing a package, that's the way to go.
> On your development machine you might want to run a stock version of
> qgis and a self-compiled one, so you don't want to install the second
> ont into /usr as well. In this case you can either export
> LD_LIBRARY_PATH (include in .bash_profile to set it automatically) or
> you can add the path it in /etc/ld.so.conf (add a file
> to /etc/ld.so.conf.d if supported by your distro).
> Regards,
> Matthias
> On Fri, 2012-05-25 at 09:38 +0200, Andreas Neumann wrote:
>> Thanks Stefan and Kimaidou
>> Setting LD_LIBRARY_PATH seems to work. It is strange. I was assuming
>> that /usr/local/lib was searched by default anyway. After all this is
>> the directory for libraries (next to /usr/lib )
>> Well - always some mysteries we can't understand ...
>> Thanks for helping me to solve the problem,
>> Andreas
>> On Fri, 25 May 2012 07:30:13 +0000, Ziegler Stefan wrote:
>>> Hi Andi
>>> I solved it by exporting LD_LIBRARY_PATH:
>>> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
>>> It's a bit strange since I think it used to work without this....
>>> Regards
>>> Stefan
>>>> -----Ursprüngliche Nachricht-----
>>>> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
>>>> bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
>>>> Gesendet: Freitag, 25. Mai 2012 09:25
>>>> An: qgis-developer
>>>> Betreff: [Qgis-developer] Library linking problems when release
>>>> 1.8
>>>> Hi,
>>>> Whenever there is a change in the major version of QGIS, e.g. 1.7
>>>> to
>>>> 1.9 and most recently the switch back from 1.9 to 1.8 I am running
>>>> into problems.
>>>> The compile runs fine but when I try to start it I get this
>>>> message:
>>>> error while loading shared libraries: libqgis_core.so.1.8.0: cannot
>>>> open shared object
>>>> file: No such file or directory
>>>> But the libqgis_core.so.1.8.0 is present in /usr/local/lib
>>>> I removed the build directory and ran ccmake .. and cmake .. again,
>>>> but
>>>> it doesn't solve this problem that it can't find the library that
>>>> obviously is present and recent on my machine.
>>>> I would very much appreciate if someone could help me out here.
>>>> Thanks a lot,
>>>> Andreas
>>>> Andreas Neumann
>>>> Böschacherstrasse 10A
>>>> 8624 Grüt (Gossau ZH)
>>>> Switzerland
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
