[Qgis-developer] Fix for bug #4521 and possible improvements to maptips
Giovanni Manghi
giovanni.manghi at faunalia.pt
Sun May 27 14:03:48 PDT 2012
> I have submitted a patch to fix the bug related to the map tip
> function and projection-on-the-fly. It would be great if someone could
> review it and get it into master before 1.8. This is my first attemp
> to contribute to the qgis project so I might have missed something
> regarding the coding conventions or some other part, but hopefully
> not. I also have a patch with some, IMO, improvements on the map tips.
> I think it would be useful to not only be able to see just one field
> (the display field), but to see all of the attributes and values of a
> feature in the map tip. This should be a choice and the prefered
> method should be set in the settings. See attached screenshots. Is
> there any interest in submitting this into master after 1.8 is out?
it seems that the patch was applied or the bug was fixed anyway
http://hub.qgis.org/issues/4521#note-11
cheers!
-- Giovanni --
