[Qgis-developer] TestQgsCoordinateReferenceSystem failed
Etienne Tourigny
etourigny.dev at gmail.com
Mon May 28 20:31:59 PDT 2012
I assume you are using a 32-bit version of Ubuntu 11.04? I don't see
this using 64bit ubuntu, gdal 1.8.1
It seems that gdal in 64-bits linux reports differently than i386 by 1 digit.
I guess a better test would be to test for towgs84 parameters (either
in proj.4 string, or qgscoordinatesystem)
Compare the results of today's autotest (lucid i386 vs. amd64) using gdal 1.6.3
lucid i386: http://dash.orfeo-toolbox.org/testDetails.php?test=10064978&build=85452
XFAIL : TestQgsCoordinateReferenceSystem::createFromESRIWkt()
expected failure with GDAL 1630 : test 0 PROJ.4 = [ +proj=utm +zone=48
+a=6377276.345 +b=6356075.413140239 +units=m +no_defs ] expecting [
+proj=utm +zone=48 +a=6377276.345 +b=6356075.41314024
+towgs84=198,881,317,0,0,0,0 +units=m +no_defs ]
lucid amd64: http://dash.orfeo-toolbox.org/testDetails.php?test=10066758&build=85457
+a=6377276.345 +b=6356075.41314024 +units=m +no_defs ] expecting [
Plus ubuntugis i386 failed because of the same precision issue,
whereas lucid-ubuntugis-amd64 passed
http://dash.orfeo-toolbox.org/testDetails.php?test=10066805&build=85462
FAIL! : TestQgsCoordinateReferenceSystem::createFromESRIWkt() 'false'
returned FALSE. (test 0 PROJ.4 = [ +proj=utm +zone=48 +a=6377276.345
+b=6356075.413140239 +towgs84=198,881,317,0,0,0,0 +units=m +no_defs ]
expecting [ +proj=utm +zone=48 +a=6377276.345 +b=6356075.41314024
+towgs84=198,881,317,0,0,0,0 +units=m +no_defs ])
Etienne
On Mon, May 28, 2012 at 11:01 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> can you post the entire (non-debug) output of the test, which includes
> gdal+proj version ?
> I tested with gdal (1.8.1) and I didn't run into that problem. It's
> possible that gdal-1.8.0 gives different results. The important part
> is the +towgs84 parameters, so the test should be relaxed instead of
> testing for exact proj4 string match.
> Etienne
> On Mon, May 28, 2012 at 10:46 PM, Giuseppe Sucameli
> <brush.tyler at gmail.com> wrote:
>> Hi all,
>> one of the CRS tests fails running it from latest master (9859709e9)
>> running against GDAL 1.8.0 on Ubuntu 11.04:
>> Loc: [/home/brushtyler/projects/sources/qgis/tests/src/core/testqgscoordinatereferencesystem.cpp(221)]
>> The difference is due to the rounded +b value in the hardcoded version
>> (...24 vs. ...239).
>> Does the fail depends on the GDAL version or is the hardcoded
>> proj4string wrong?
>> Regards.
>> Giuseppe Sucameli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
