[Qgis-developer] WMTS capabilities error
Richard Duivenvoorde
rdmailings at duif.net
Tue May 29 02:37:06 PDT 2012
Hi Devs,
testing the our national WMTS service with the WMTS branch of jef a
couple of weeks ago, I was able to retrieve the capabilities and show
the map.
But in current RC1 version (I have both versions parallel running here),
I get an error for the getcapabilities request in QGIS:
Could not understand the response. The wms provider said:
Could not get WMS capabilities in the expected format (DTD): no
WMS_Capabilities or WMT_MS_Capabilities found.
This might be due to an incorrect WMS Server URL.
Tag:Capabilities
Response was:
<Capabilities xmlns="http://www.opengis.net/wmts/1.0"
xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:gml="http://www.opengis.net/gml"
xsi:schemaLocation="http://www.opengis.net/wmts/1.0
http://geowebcache.org/schema/opengis/wmts/1.0.0/wmtsGetCapabilities_response.xsd"
version="1.0.0">
Is RC1 more strict in it's validation of the schema?
What is the easiest way to check what the problem is here?
If somebody wants to test:
The service url is:
http://geodata.nationaalgeoregister.nl/tiles/service/wmts?
BUT be aware that it is serving tiles in EPSG:28992 , maybe that is the
problem?
If you use this url as service url in QGIS you will see the tiles as
WMS-C (also in EPSG:28992):
http://geodata.nationaalgeoregister.nl/wmsc?tiled=true
Regards,
