[Qgis-developer] QGIS' "fetch python plugin" does not see my plugin
Agustin Lobo alobolistas at gmail.com
Tue May 29 03:18:01 PDT 2012
Bruno,
I do see (and have installed) Earth Beat 0.75
(qgis 1.7.4 on ubuntu 10:04)
Do you have
http://plugins.qgis.org/plugins/plugins.xml
as repo ?
Agus
2012/5/29 Bruno Combal <bruno.combal at gmail.com>:
> Dear all,
> I've made a little plugin, Earthbeat, still in experimental phase.
> The plugin is hosted on http://plugins.qgis.org/plugins/
> My problem is that the plugin does not show in QGIS "fetch python plugin" panel
> (I turned on the "show all plugins, even those marked as experimental").
> Could someone tell me what I should do to allow the plugin-fetch command
> to retrieve my plugin from plugins.qgis.org?
> To give more details:
> 1. I sent the plugins as a zip for approval.
> 2. after approval, zip was visible on http://plugins.qgis.org/plugins/
> but not in the QGIS fetch command.
> 3. I made a git repository, thinking (wrongly) that it would help
> http://hub.qgis.org/projects/earthbeat/repository
> My codes come with a metadata.txt file indicating the location of the git repository.
> Maybe I should not have both zip+git?
> Or are there some permissions to fix?
> thanks!
> Bruno
> Qgis-developer mailing list
