[Qgis-developer] Sextante: v.buffer angle does not work
Paolo Cavallini
cavallini at faunalia.it
Thu May 31 02:19:57 PDT 2012
Il 30/05/2012 18:33, Victor Olaya ha scritto:
> mmmm, I had splitted it, and in fact this algorithm just calls the
> angle option, but it still complains
> This is your command line
> v.buffer input=tmp1338388935286 angle=90 tolerance=0.01 -s -c
> output=output --overwrite
> Any GRASS expert can help?
Fixed in r197 - thanks Victor and Moritz for the prompt solution.
However, v.buffer.column now throws an error:
Numero di nodi: 100
Numero di primitive:100
Numero di punti:100
Numero di linee:0
Numero di confini:0
Numero di centroidi:0
Numero di aree:0
Numero di isole:0
Buffering lines...
Segmentation fault
ERRORE: Impossibile aprire il vettoriale <output at user> sul livello 2.
Provare a ricostruire la topologia con v.build.
I suspect issues with layer<>1 are a general problem.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
