[Qgis-developer] Sextante: v.buffer angle does not work
Victor Olaya
volayaf at gmail.com
Wed May 30 09:33:19 PDT 2012
mmmm, I had splitted it, and in fact this algorithm just calls the
angle option, but it still complains
This is your command line
v.buffer input=tmp1338388935286 angle=90 tolerance=0.01 -s -c
output=output --overwrite
and it says
ERRORE: Select a buffer distance/minordistance/angle or column, but not
both.
But it's only passing an angle, not any of the other options!!!. Or
you are not supposed to use tolerance with the angle option?
Any GRASS expert can help?
