[Qgis-developer] String freeze and call for final translation updates
Etienne Tourigny
etourigny.dev at gmail.com
Thu May 31 17:19:37 PDT 2012
Looks like that issue was closed, and the last blocker (CRS issues) is
ok by me, but needs to be tested with an i386 linux build (ideally
from the nightlies).
http://hub.qgis.org/issues/5598
On Thu, May 31, 2012 at 7:05 AM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
> Hi all,
>> it seems a new regression has surfaced
>> http://hub.qgis.org/issues/5665
>> I can confirm the issue on master and in 1.7.4 used to work. Anyway I
>> would like to have others to check this.
> Martin seems to have promptly fixed this (the original issuers is still
> checking the fix).
> Meanwhile feedback is needed about this regression
> http://hub.qgis.org/issues/5678
> cheers
> -- Giovanni --
> Qgis-developer mailing list
