[Qgis-developer] Sextante broken on Master
Victor Olaya volayaf at gmail.com
Thu Nov 8 11:30:42 PST 2012
In the current master version, the modeler folder should default to a
folder in the user folder. It seems that it is trying to create the folder
where the example models are. Probably you have a different setting for you
models folder? change it in the sextante_qgis.conf file in your sextante
folder (in your user dir), and see if it works.
sorry for all this problems with the models and scripts folders...
2012/11/8 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> Hi Victor,
> > Not the problem I thought it was...but it should be fixed anyway
> just updated on Ubuntu, now I get
> Couldn't load plugin sextante due an error when calling its
> classFactory() method
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 188, in
> startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File "/usr/share/qgis/python/plugins/sextante/__init__.py", line 46,
> in classFactory
>     return SextantePlugin(iface)
>   File "/usr/share/qgis/python/plugins/sextante/SextantePlugin.py",
> line 56, in __init__
>     Sextante.initialize()
>   File "/usr/share/qgis/python/plugins/sextante/core/Sextante.py",
> line 133, in initialize
>     Sextante.modeler.initializeSettings();
>   File
> "/usr/share/qgis/python/plugins/sextante/modeler/ModelerAlgorithmProvider.py",
> line 49, in initializeSettings
>     SextanteConfig.addSetting(Setting(self.getDescription(),
> ModelerUtils.MODELS_FOLDER, "Models folder",
> ModelerUtils.modelsFolder()))
>   File "/usr/share/qgis/python/plugins/sextante/modeler/ModelerUtils.py",
> line 40, in modelsFolder
>     mkdir(folder)
>   File "/usr/share/qgis/python/plugins/sextante/core/SextanteUtils.py",
> line 87, in mkdir
>     os.mkdir(newdir)
> OSError: [Errno 13] Permission denied:
> '/usr/share/qgis/python/plugins/sextante/modeler/models'
> cheers!
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121108/b53dee39/attachment.html>
