[Qgis-developer] Sextante broken on Master
Victor Olaya
volayaf at gmail.com
Fri Nov 9 15:39:43 PST 2012
I have pushed a few changes, among them a fix to handle missing examples
folder.
However, all example folders should appear now, and the scripts examples
folder should in fact contain an example script (I plan to add more...)
Hope this helps...and that i have done it write with the CMake files this
time :-) I would be great if someone more experienced with CMake could
check that in case there are still problems related to that....
Thanks!
2012/11/9 Bob and Deb <bobdebm at gmail.com>
> Just compiled the latest master and got the error:
> OSError: [Errno 2] No such file or directory:
> '/usr/local/share/qgis/python/plugins/sextante/script/scripts'
> Btw, I haven't been able to find sextante_qgis.conf anywhere on my system.
> On Thu, Nov 8, 2012 at 2:30 PM, Sandro Santilli <strk at keybit.net> wrote:
>> I'm getting an error too, when running qgis from the output/bin dir:
>> '/usr/src/qgis/Quantum-GIS/b/output/python/plugins/sextante/script/scripts'
>> --strk;
>> On Thu, Nov 08, 2012 at 08:30:42PM +0100, Victor Olaya wrote:
>> > In the current master version, the modeler folder should default to a
>> > folder in the user folder. It seems that it is trying to create the
>> folder
>> > where the example models are. Probably you have a different setting for
>> you
>> > models folder? change it in the sextante_qgis.conf file in your sextante
>> > folder (in your user dir), and see if it works.
>> > sorry for all this problems with the models and scripts folders...
>> > 2012/11/8 Giovanni Manghi <giovanni.manghi at faunalia.pt>
>> > > Hi Victor,
>> > > > Not the problem I thought it was...but it should be fixed anyway
>> > > just updated on Ubuntu, now I get
>> > > Couldn't load plugin sextante due an error when calling its
>> > > classFactory() method
>> > > Traceback (most recent call last):
>> > > File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 188, in
>> > > startPlugin
>> > > plugins[packageName] = package.classFactory(iface)
>> > > File "/usr/share/qgis/python/plugins/sextante/__init__.py", line 46,
>> > > in classFactory
>> > > return SextantePlugin(iface)
>> > > File "/usr/share/qgis/python/plugins/sextante/SextantePlugin.py",
>> > > line 56, in __init__
>> > > Sextante.initialize()
>> > > File "/usr/share/qgis/python/plugins/sextante/core/Sextante.py",
>> > > line 133, in initialize
>> > > Sextante.modeler.initializeSettings();
>> > > File
>> "/usr/share/qgis/python/plugins/sextante/modeler/ModelerAlgorithmProvider.py",
>> > > line 49, in initializeSettings
>> > > SextanteConfig.addSetting(Setting(self.getDescription(),
>> > > ModelerUtils.MODELS_FOLDER, "Models folder",
>> > > ModelerUtils.modelsFolder()))
>> > > File
>> "/usr/share/qgis/python/plugins/sextante/modeler/ModelerUtils.py",
>> > > line 40, in modelsFolder
>> > > mkdir(folder)
>> > > File
>> "/usr/share/qgis/python/plugins/sextante/core/SextanteUtils.py",
>> > > line 87, in mkdir
>> > > os.mkdir(newdir)
>> > > OSError: [Errno 13] Permission denied:
>> > > '/usr/share/qgis/python/plugins/sextante/modeler/models'
>> > > cheers!
>> > > _______________________________________________
>> > > Qgis-developer mailing list
>> > > Qgis-developer at lists.osgeo.org
>> > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> http://www.cartodb.com - Map, analyze and build applications with your
>> data
>> ~~ http://strk.keybit.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121110/a9b3f559/attachment.html>
