[Qgis-developer] Sextante broken on Master
Bob and Deb bobdebm at gmail.com
Fri Nov 9 14:22:04 PST 2012
Just compiled the latest master and got the error:
 OSError: [Errno 2] No such file or directory:
'/usr/local/share/qgis/python/plugins/sextante/script/scripts'
Btw, I haven't been able to find sextante_qgis.conf anywhere on my system.
On Thu, Nov 8, 2012 at 2:30 PM, Sandro Santilli <strk at keybit.net> wrote:
> I'm getting an error too, when running qgis from the output/bin dir:
> '/usr/src/qgis/Quantum-GIS/b/output/python/plugins/sextante/script/scripts'
> --strk;
> On Thu, Nov 08, 2012 at 08:30:42PM +0100, Victor Olaya wrote:
> > In the current master version, the modeler folder should default to a
> > folder in the user folder. It seems that it is trying to create the
> folder
> > where the example models are. Probably you have a different setting for
> you
> > models folder? change it in the sextante_qgis.conf file in your sextante
> > folder (in your user dir), and see if it works.
> > sorry for all this problems with the models and scripts folders...
> > 2012/11/8 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> > > Hi Victor,
> > > > Not the problem I thought it was...but it should be fixed anyway
> > > just updated on Ubuntu, now I get
> > > Couldn't load plugin sextante due an error when calling its
> > > classFactory() method
> > > Traceback (most recent call last):
> > >   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 188, in
> > > startPlugin
> > >     plugins[packageName] = package.classFactory(iface)
> > >   File "/usr/share/qgis/python/plugins/sextante/__init__.py", line 46,
> > > in classFactory
> > >     return SextantePlugin(iface)
> > >   File "/usr/share/qgis/python/plugins/sextante/SextantePlugin.py",
> > > line 56, in __init__
> > >     Sextante.initialize()
> > >   File "/usr/share/qgis/python/plugins/sextante/core/Sextante.py",
> > > line 133, in initialize
> > >     Sextante.modeler.initializeSettings();
> > >   File
> "/usr/share/qgis/python/plugins/sextante/modeler/ModelerAlgorithmProvider.py",
> > > line 49, in initializeSettings
> > >     SextanteConfig.addSetting(Setting(self.getDescription(),
> > > ModelerUtils.MODELS_FOLDER, "Models folder",
> > > ModelerUtils.modelsFolder()))
> > >   File
> "/usr/share/qgis/python/plugins/sextante/modeler/ModelerUtils.py",
> > > line 40, in modelsFolder
> > >     mkdir(folder)
> > >   File "/usr/share/qgis/python/plugins/sextante/core/SextanteUtils.py",
> > > line 87, in mkdir
> > >     os.mkdir(newdir)
> > > OSError: [Errno 13] Permission denied:
> > > '/usr/share/qgis/python/plugins/sextante/modeler/models'
> > > cheers!
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
>                                        ~~ http://strk.keybit.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121109/409dfd43/attachment.html>
