[Qgis-developer] Server features
G. Allegri giohappy at gmail.com
Thu Nov 15 01:09:01 PST 2012
> What I really miss in QGIS server compared to UNM mapserver is the
> possibility to keep a certain space around the edge of the generated output
> free of labels (UMN Mapserver has had that already in V 5.? or even
> earlier). This is a must-have if we want to integrate mapcache because
> otherwise there will be broken labels and tiles will not fit to each other
> labelwise.
I totally agree. As I said in an earlier reply, metatiling and buffering
are a must to serve tiled caches.
giovanni
> just my 2 ct
> Bernhard
> Am 15.11.2012 08:57, schrieb Andreas Neumann:
>> Hi,
>> For 90% of my projects performance is really good. For the remaining
>> 10%, rather complext projects, I would say it is good enough, but it
>> could be "snappier".
>> I am specifically talking about the "Leitungskataster" project, the
>> project displaying all supply lines and waste-water lines, containing
>> cadastral data, electricity, gaz, water, communication, waste-water and
>> heating.
>> These complex projects typically have:
>> * a lot of layers (around 70 layers)
>> * a lot of rules in the layer symbology
>> * automatically placed labels along lines
>> * dash patterns - almost all the lines are dashed
>> * SVG symbols
>> I will have to do my own homework. I will probably have to reduce the
>> number of layers by using views.
>> And to be honest, I haven't set up the same project on UMN mapserver to
>> compare whether it is really faster.
>> I don't know yet where the bottlenecks are (too many layers, too many
>> rules, too many rules, too many labels?).
>> Thanks,
>> Andreas
>> Am 14.11.2012 21:13, schrieb Marco Hugentobler:
>>> Hi all
>>> Performance is a complex topic, it essentially depends what you are
>>> testing ( few complex polygons, many small polygons, type of raster,
>>> lots of labels, ...).
>>> I'm regularly profiling some of my important server projects (e.g. WMS
>>> of cadastral survey). One thing that takes up a lot of render time is
>>> the drawing of the labels (only the rendering, not the placement).
>>> I think this is because they are rendered using QPainterPath and not
>>> with QPainter->drawText (but it might be difficult to render the buffer
>>> using drawText).
>>> And don't forget that normally the transfer of the image over the
>>> internet takes more time than the WMS rendering itself. So don't forget
>>> to use jpg for rasters and the improved png8 for vectors. It can improve
>>> perceived performance by a factor of 3 or 4.
>>> Regards,
>>> Marco
>>> On 14.11.2012 19:57, Andreas Neumann wrote:
>>>> Lets say that speed of QGIS Server is good enough for most of my
>>>> projects. But it could be faster for more complex rendering and
>>>> labeling.
>>>> UMN feels faster than QGIS Server - but I don't have time for double
>>>> configurations for desktop and web. Plus - it is so much easier to
>>>> configure QGIS projects compared to editing mapfiles.
>>>> "G. Allegri"<giohappy at gmail.com>  schrieb:
>>>>          The one thing were UMN Mapserver is a much better is
>>>>          performance. This
>>>>          is where we should really catch up.
>>>>      I would put this to the higher position! I don't know where the
>>>>      effort should be put, because I suppose it's something deep in the
>>>>      rendering engine of QGis. Do you see bottlenecks at the server
>>>> level?
>>>>      I would also add a point to the whishlist: Qgis Server Python API
>>>>      giovanni
>>>>      2012/11/14 kimaidou<kimaidou at gmail.com<**mailto:kimaidou at gmail.com
>>>>          Hi
>>>>          2012/11/14 Vincent Picavet<vincent.ml at oslandia.**com<vincent.ml at oslandia.com>
>>>>          <mailto:vincent.ml at oslandia.**com <vincent.ml at oslandia.com>>>
>>>>              Hi,
>>>>              >  * templates for HTML popups (already done this in
>>>>              Lizmap, but why not
>>>>              >  having it in Qgis)
>>>>              You mean accessing the templates through QGIS server ?
>>>>              Because html popups
>>>>              already are in QGIS :)
>>>>          I mean through Qgis Server (in respect to this thread title ;)
>>>>          Just exposing methods for the server must do it, as Andreas
>>>>          proposed.
>>>>              We should have a look at PyWPS too, which could be an easy
>>>>              way to provide WPS
>>>>              services around QGIS API.
>>>>          Yes, pyWPS could help provide this feature, but we still need
>>>>          a way so that QGIS Server can use python plugins / processes,
>>>>          etc.. I remember discussion about this during last hackfests,
>>>>          but I do not know if someone gave it a try.
>>>>          Anyway, +10000 for focusing on performance first, which is the
>>>>          key "feature" for a Server.
>>>>          Michael
>>>>              Vincent
>>>>              >  Good evening
>>>>              >  Michael
>>>>              >  2012/11/14 G. Allegri<giohappy at gmail.com
>>>>              <mailto:giohappy at gmail.com>>
>>>>              >  >  >  - integrated tiling
>>>>              >  >>  Why not integrating mapcache directly to mutualize
>>>>              effort on this part ?
>>>>              >  >>  Mapcache can be used standalone, and could read its
>>>>              parameters directly
>>>>              >  >>  from a
>>>>              >  >>  qgis configuration file. No need to reinvent the
>>>>              wheel here, or would
>>>>              >  >>  there be a
>>>>              >  >>  good reason to it ?
>>>>              >  >  I think that a tile generator from the QGis Desktop
>>>>              side would suffice.
>>>>              >  >  Any other TMS/WMS-T server could use the tile
>>>> structure.
>>>>              >  >>  >  - mask layers
>>>>              >  >>  That would be great to have in QGIS indeed. It would
>>>>              mean having for
>>>>              >  >>  each layer an attached mask layer, which is not
>>>>              displayed but only used
>>>>              >  >>  to define
>>>>              >  >>  hidden places.
>>>>              >  >>  >  - symbol placement
>>>>              >  >>  >  - label offsets
>>>>              >  >>  That's for qgis symbology, not directly a qgis
>>>> server
>>>>              issue. Label
>>>>              >  >>  offset in
>>>>              >  >>  mapserver definitly looks cool !
>>>>              >  >  I agree Vincent.
>>>>              >  >>  Vincent
>>>>              >  >>  ______________________________**_________________
>>>>              >  >>  Qgis-developer mailing list
>>>>              >  >>  Qgis-developer at lists.osgeo.org
>>>>              <mailto:Qgis-developer at lists.**osgeo.org<Qgis-developer at lists.osgeo.org>
>>>>              >  >>  http://lists.osgeo.org/**mailman/listinfo/qgis-**
>>>> developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>>              http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>> Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail
>>>> gesendet.
>> __________ Information from ESET Mail Security, version of virus
>> signature database 7693 (20121114) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> Bernhard Ströbl
> Anwendungsbetreuer GIS
> Kommunale Immobilien Jena
> Am Anger 26
> 07743 Jena
> Tel.: 03641 49- 5190
> E-Mail: bernhard.stroebl at jena.de
> Internet: www.kij.de
> Eigenbetrieb der Stadt Jena
> Werkleiter: Dr. Götz Blankenburg
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121115/8de5ae3d/attachment-0001.html>
