[Qgis-developer] Server features
kimaidou
kimaidou at gmail.com
Thu Nov 15 01:14:34 PST 2012
A very short answer here : have you checked the Lizmap ability to create
automatic tile cache ? It supports metatiling too.
As I know, it is the only open-source solution which can simply use a QGIS
project, build a map and dynamically create tile caching with metatile
support.
Sorry for this intervention about Lizmap. But as it is open-source, and
deeply dependant of QGIS, I think people won't mind. Tell me otherwise, I
will stop.
Cheers
Michael
2012/11/15 G. Allegri <giohappy at gmail.com>
> What I really miss in QGIS server compared to UNM mapserver is the
>> possibility to keep a certain space around the edge of the generated output
>> free of labels (UMN Mapserver has had that already in V 5.? or even
>> earlier). This is a must-have if we want to integrate mapcache because
>> otherwise there will be broken labels and tiles will not fit to each other
>> labelwise.
> I totally agree. As I said in an earlier reply, metatiling and buffering
> are a must to serve tiled caches.
> giovanni
>> just my 2 ct
>> Bernhard
>> Am 15.11.2012 08:57, schrieb Andreas Neumann:
>>> Hi,
>>> For 90% of my projects performance is really good. For the remaining
>>> 10%, rather complext projects, I would say it is good enough, but it
>>> could be "snappier".
>>> I am specifically talking about the "Leitungskataster" project, the
>>> project displaying all supply lines and waste-water lines, containing
>>> cadastral data, electricity, gaz, water, communication, waste-water and
>>> heating.
>>> These complex projects typically have:
>>> * a lot of layers (around 70 layers)
>>> * a lot of rules in the layer symbology
>>> * automatically placed labels along lines
>>> * dash patterns - almost all the lines are dashed
>>> * SVG symbols
>>> I will have to do my own homework. I will probably have to reduce the
>>> number of layers by using views.
>>> And to be honest, I haven't set up the same project on UMN mapserver to
>>> compare whether it is really faster.
>>> I don't know yet where the bottlenecks are (too many layers, too many
>>> rules, too many rules, too many labels?).
>>> Thanks,
>>> Andreas
>>> Am 14.11.2012 21:13, schrieb Marco Hugentobler:
>>>> Hi all
>>>> Performance is a complex topic, it essentially depends what you are
>>>> testing ( few complex polygons, many small polygons, type of raster,
>>>> lots of labels, ...).
>>>> I'm regularly profiling some of my important server projects (e.g. WMS
>>>> of cadastral survey). One thing that takes up a lot of render time is
>>>> the drawing of the labels (only the rendering, not the placement).
>>>> I think this is because they are rendered using QPainterPath and not
>>>> with QPainter->drawText (but it might be difficult to render the buffer
>>>> using drawText).
>>>> And don't forget that normally the transfer of the image over the
>>>> internet takes more time than the WMS rendering itself. So don't forget
>>>> to use jpg for rasters and the improved png8 for vectors. It can improve
>>>> perceived performance by a factor of 3 or 4.
>>>> Regards,
>>>> Marco
>>>> On 14.11.2012 19:57, Andreas Neumann wrote:
>>>>> Lets say that speed of QGIS Server is good enough for most of my
>>>>> projects. But it could be faster for more complex rendering and
>>>>> labeling.
>>>>> UMN feels faster than QGIS Server - but I don't have time for double
>>>>> configurations for desktop and web. Plus - it is so much easier to
>>>>> configure QGIS projects compared to editing mapfiles.
>>>>> "G. Allegri"<giohappy at gmail.com> schrieb:
>>>>> The one thing were UMN Mapserver is a much better is
>>>>> performance. This
>>>>> is where we should really catch up.
>>>>> I would put this to the higher position! I don't know where the
>>>>> effort should be put, because I suppose it's something deep in the
>>>>> rendering engine of QGis. Do you see bottlenecks at the server
>>>>> level?
>>>>> I would also add a point to the whishlist: Qgis Server Python API
>>>>> giovanni
>>>>> 2012/11/14 kimaidou<kimaidou at gmail.com<**mailto:
>>>>> kimaidou at gmail.com>>
>>>>> Hi
>>>>> 2012/11/14 Vincent Picavet<vincent.ml at oslandia.**com<vincent.ml at oslandia.com>
>>>>> <mailto:vincent.ml at oslandia.**com <vincent.ml at oslandia.com>>>
>>>>> Hi,
>>>>> > * templates for HTML popups (already done this in
>>>>> Lizmap, but why not
>>>>> > having it in Qgis)
>>>>> You mean accessing the templates through QGIS server ?
>>>>> Because html popups
>>>>> already are in QGIS :)
>>>>> I mean through Qgis Server (in respect to this thread title ;)
>>>>> Just exposing methods for the server must do it, as Andreas
>>>>> proposed.
>>>>> We should have a look at PyWPS too, which could be an easy
>>>>> way to provide WPS
>>>>> services around QGIS API.
>>>>> Yes, pyWPS could help provide this feature, but we still need
>>>>> a way so that QGIS Server can use python plugins / processes,
>>>>> etc.. I remember discussion about this during last hackfests,
>>>>> but I do not know if someone gave it a try.
>>>>> Anyway, +10000 for focusing on performance first, which is the
>>>>> key "feature" for a Server.
>>>>> Michael
>>>>> Vincent
>>>>> > Good evening
>>>>> > Michael
>>>>> > 2012/11/14 G. Allegri<giohappy at gmail.com
>>>>> <mailto:giohappy at gmail.com>>
>>>>> > > > - integrated tiling
>>>>> > >> Why not integrating mapcache directly to mutualize
>>>>> effort on this part ?
>>>>> > >> Mapcache can be used standalone, and could read its
>>>>> parameters directly
>>>>> > >> from a
>>>>> > >> qgis configuration file. No need to reinvent the
>>>>> wheel here, or would
>>>>> > >> there be a
>>>>> > >> good reason to it ?
>>>>> > > I think that a tile generator from the QGis Desktop
>>>>> side would suffice.
>>>>> > > Any other TMS/WMS-T server could use the tile
>>>>> structure.
>>>>> > >> > - mask layers
>>>>> > >> That would be great to have in QGIS indeed. It
>>>>> would
>>>>> mean having for
>>>>> > >> each layer an attached mask layer, which is not
>>>>> displayed but only used
>>>>> > >> to define
>>>>> > >> hidden places.
>>>>> > >> > - symbol placement
>>>>> > >> > - label offsets
>>>>> > >> That's for qgis symbology, not directly a qgis
>>>>> server
>>>>> issue. Label
>>>>> > >> offset in
>>>>> > >> mapserver definitly looks cool !
>>>>> > > I agree Vincent.
>>>>> > >> Vincent
>>>>> > >> ______________________________**_________________
>>>>> > >> Qgis-developer mailing list
>>>>> > >> Qgis-developer at lists.osgeo.org
>>>>> <mailto:Qgis-developer at lists.**osgeo.org<Qgis-developer at lists.osgeo.org>
>>>>> > >> http://lists.osgeo.org/**mailman/listinfo/qgis-**
>>>>> developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>>> Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail
>>>>> gesendet.
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 7693 (20121114) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>> Bernhard Ströbl
>> Anwendungsbetreuer GIS
>> Kommunale Immobilien Jena
>> Am Anger 26
>> 07743 Jena
>> Tel.: 03641 49- 5190
>> E-Mail: bernhard.stroebl at jena.de
>> Internet: www.kij.de
>> Eigenbetrieb der Stadt Jena
>> Werkleiter: Dr. Götz Blankenburg
>> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121115/a40aeefa/attachment-0001.html>
