[Qgis-developer] Server features
G. Allegri giohappy at gmail.com
Thu Nov 15 01:34:20 PST 2012
It's a good thing to have Lizmap metatiling and caching, and I congratulate
for your work.
Anyway, having tile caching and metatiling at the server level would
provide a larger benefit.
We will consider it fro founding...
giovanni
2012/11/15 kimaidou <kimaidou at gmail.com>
> A very short answer here : have you checked the Lizmap ability to create
> automatic tile cache ? It supports metatiling too.
> As I know, it is the only open-source solution which can simply use a QGIS
> project, build a map and dynamically create tile caching with metatile
> support.
> Sorry for this intervention about Lizmap. But as it is open-source, and
> deeply dependant of QGIS, I think people won't mind. Tell me otherwise, I
> will stop.
> Cheers
> Michael
> 2012/11/15 G. Allegri <giohappy at gmail.com>
>> What I really miss in QGIS server compared to UNM mapserver is the
>>> possibility to keep a certain space around the edge of the generated output
>>> free of labels (UMN Mapserver has had that already in V 5.? or even
>>> earlier). This is a must-have if we want to integrate mapcache because
>>> otherwise there will be broken labels and tiles will not fit to each other
>>> labelwise.
>> I totally agree. As I said in an earlier reply, metatiling and buffering
>> are a must to serve tiled caches.
>> giovanni
>>> just my 2 ct
>>> Bernhard
>>> Am 15.11.2012 08:57, schrieb Andreas Neumann:
>>>> Hi,
>>>> For 90% of my projects performance is really good. For the remaining
>>>> 10%, rather complext projects, I would say it is good enough, but it
>>>> could be "snappier".
>>>> I am specifically talking about the "Leitungskataster" project, the
>>>> project displaying all supply lines and waste-water lines, containing
>>>> cadastral data, electricity, gaz, water, communication, waste-water and
>>>> heating.
>>>> These complex projects typically have:
>>>> * a lot of layers (around 70 layers)
>>>> * a lot of rules in the layer symbology
>>>> * automatically placed labels along lines
>>>> * dash patterns - almost all the lines are dashed
>>>> * SVG symbols
>>>> I will have to do my own homework. I will probably have to reduce the
>>>> number of layers by using views.
>>>> And to be honest, I haven't set up the same project on UMN mapserver to
>>>> compare whether it is really faster.
>>>> I don't know yet where the bottlenecks are (too many layers, too many
>>>> rules, too many rules, too many labels?).
>>>> Thanks,
>>>> Andreas
>>>> Am 14.11.2012 21:13, schrieb Marco Hugentobler:
>>>>> Hi all
>>>>> Performance is a complex topic, it essentially depends what you are
>>>>> testing ( few complex polygons, many small polygons, type of raster,
>>>>> lots of labels, ...).
>>>>> I'm regularly profiling some of my important server projects (e.g. WMS
>>>>> of cadastral survey). One thing that takes up a lot of render time is
>>>>> the drawing of the labels (only the rendering, not the placement).
>>>>> I think this is because they are rendered using QPainterPath and not
>>>>> with QPainter->drawText (but it might be difficult to render the buffer
>>>>> using drawText).
>>>>> And don't forget that normally the transfer of the image over the
>>>>> internet takes more time than the WMS rendering itself. So don't forget
>>>>> to use jpg for rasters and the improved png8 for vectors. It can
>>>>> improve
>>>>> perceived performance by a factor of 3 or 4.
>>>>> Regards,
>>>>> Marco
>>>>> On 14.11.2012 19:57, Andreas Neumann wrote:
>>>>>> Lets say that speed of QGIS Server is good enough for most of my
>>>>>> projects. But it could be faster for more complex rendering and
>>>>>> labeling.
>>>>>> UMN feels faster than QGIS Server - but I don't have time for double
>>>>>> configurations for desktop and web. Plus - it is so much easier to
>>>>>> configure QGIS projects compared to editing mapfiles.
>>>>>> "G. Allegri"<giohappy at gmail.com>  schrieb:
>>>>>>          The one thing were UMN Mapserver is a much better is
>>>>>>          performance. This
>>>>>>          is where we should really catch up.
>>>>>>      I would put this to the higher position! I don't know where the
>>>>>>      effort should be put, because I suppose it's something deep in
>>>>>> the
>>>>>>      rendering engine of QGis. Do you see bottlenecks at the server
>>>>>> level?
>>>>>>      I would also add a point to the whishlist: Qgis Server Python
>>>>>> API ;)
>>>>>>      giovanni
>>>>>>      2012/11/14 kimaidou<kimaidou at gmail.com<**mailto:
>>>>>> kimaidou at gmail.com>>
>>>>>>          Hi
>>>>>>          2012/11/14 Vincent Picavet<vincent.ml at oslandia.**com<vincent.ml at oslandia.com>
>>>>>>          <mailto:vincent.ml at oslandia.**com <vincent.ml at oslandia.com>
>>>>>>              Hi,
>>>>>>              >  * templates for HTML popups (already done this in
>>>>>>              Lizmap, but why not
>>>>>>              >  having it in Qgis)
>>>>>>              You mean accessing the templates through QGIS server ?
>>>>>>              Because html popups
>>>>>>              already are in QGIS :)
>>>>>>          I mean through Qgis Server (in respect to this thread title
>>>>>>          Just exposing methods for the server must do it, as Andreas
>>>>>>          proposed.
>>>>>>              We should have a look at PyWPS too, which could be an
>>>>>> easy
>>>>>>              way to provide WPS
>>>>>>              services around QGIS API.
>>>>>>          Yes, pyWPS could help provide this feature, but we still need
>>>>>>          a way so that QGIS Server can use python plugins / processes,
>>>>>>          etc.. I remember discussion about this during last hackfests,
>>>>>>          but I do not know if someone gave it a try.
>>>>>>          Anyway, +10000 for focusing on performance first, which is
>>>>>> the
>>>>>>          key "feature" for a Server.
>>>>>>          Michael
>>>>>>              Vincent
>>>>>>              >  Good evening
>>>>>>              >  Michael
>>>>>>              >  2012/11/14 G. Allegri<giohappy at gmail.com
>>>>>>              <mailto:giohappy at gmail.com>>
>>>>>>              >  >  >  - integrated tiling
>>>>>>              >  >>  Why not integrating mapcache directly to mutualize
>>>>>>              effort on this part ?
>>>>>>              >  >>  Mapcache can be used standalone, and could read
>>>>>> its
>>>>>>              parameters directly
>>>>>>              >  >>  from a
>>>>>>              >  >>  qgis configuration file. No need to reinvent the
>>>>>>              wheel here, or would
>>>>>>              >  >>  there be a
>>>>>>              >  >>  good reason to it ?
>>>>>>              >  >  I think that a tile generator from the QGis Desktop
>>>>>>              side would suffice.
>>>>>>              >  >  Any other TMS/WMS-T server could use the tile
>>>>>> structure.
>>>>>>              >  >>  >  - mask layers
>>>>>>              >  >>  That would be great to have in QGIS indeed. It
>>>>>> would
>>>>>>              mean having for
>>>>>>              >  >>  each layer an attached mask layer, which is not
>>>>>>              displayed but only used
>>>>>>              >  >>  to define
>>>>>>              >  >>  hidden places.
>>>>>>              >  >>  >  - symbol placement
>>>>>>              >  >>  >  - label offsets
>>>>>>              >  >>  That's for qgis symbology, not directly a qgis
>>>>>> server
>>>>>>              issue. Label
>>>>>>              >  >>  offset in
>>>>>>              >  >>  mapserver definitly looks cool !
>>>>>>              >  >  I agree Vincent.
>>>>>>              >  >>  Vincent
>>>>>>              >  >>  ______________________________**_________________
>>>>>>              >  >>  Qgis-developer mailing list
>>>>>>              >  >>  Qgis-developer at lists.osgeo.org
>>>>>>              <mailto:Qgis-developer at lists.**osgeo.org<Qgis-developer at lists.osgeo.org>
>>>>>>              >  >>  http://lists.osgeo.org/**mailman/listinfo/qgis-**
>>>>>> developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>>>>          http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>>>> Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail
>>>>>> gesendet.
>>>> __________ Information from ESET Mail Security, version of virus
>>>> signature database 7693 (20121114) __________
>>>> The message was checked by ESET Mail Security.
>>>> http://www.eset.com
>>> Bernhard Ströbl
>>> Anwendungsbetreuer GIS
>>> Kommunale Immobilien Jena
>>> Am Anger 26
>>> 07743 Jena
>>> Tel.: 03641 49- 5190
>>> E-Mail: bernhard.stroebl at jena.de
>>> Internet: www.kij.de
>>> Eigenbetrieb der Stadt Jena
>>> Werkleiter: Dr. Götz Blankenburg
>>> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121115/55f72fa2/attachment-0001.html>
