[Qgis-developer] Rule based renderer can't rotate symbols based on rotation field
Leyan
ouyang.leyan.ml at hotmail.com
Fri Nov 16 07:18:16 PST 2012
I am not sure I understand exactly what you want, there should be no
link between the rule-based renderer and the rotation settings. What is
working for a single that is not working with the rule-based renderer ?
I only have qgis Master here, but I can specify the rotation in the
rules I create. The data-defined rotation only works for ellipse
symbols, but this issue is not related to the rule-based renderer.
Which version are you using ?
Regards,
Leyan
On 11/16/2012 06:57 PM, Andreas Neumann wrote:
> Hi,
> I am in the process of cleaning up some other project, reducing the nr
> of necessary layers by changing to the rule based renderer.
> Am I missing something, or is it not possible to rotate symbols based
> on a rotation attribute when using the rule based renderer? Maybe I
> don't find it in the GUI? Or is this very important feature not yet
> present?
> Thanks,
> Andreas
