[Qgis-developer] Rule based renderer can't rotate symbols based on rotation field
Andreas Neumann
a.neumann at carto.net
Fri Nov 16 07:21:15 PST 2012
Hi Leyan,
I am also using the current master.
If am using the "categorized" or "simple" or "" renderer, there is a
"Advanced" button in the bottom right where one can choose a rotation or
scale attribute. This button and choice is not available with the
rule-based renderer.
You are right - I can use the ellipse renderer with the rule based
renderer, but I would also need it for simple symbols and SVG symbols
and for those, we cannot have data-defined settings.
So it seems that the symbology system is not yet consistent and
complete.
Andreas
On Fri, 16 Nov 2012 23:18:16 +0800, Leyan wrote:
> I am not sure I understand exactly what you want, there should be no
> link between the rule-based renderer and the rotation settings. What
> is working for a single that is not working with the rule-based
> renderer ?
> I only have qgis Master here, but I can specify the rotation in the
> rules I create. The data-defined rotation only works for ellipse
> symbols, but this issue is not related to the rule-based renderer.
> Which version are you using ?
> Regards,
> Leyan
> On 11/16/2012 06:57 PM, Andreas Neumann wrote:
>> Hi,
>> I am in the process of cleaning up some other project, reducing the
>> nr of necessary layers by changing to the rule based renderer.
>> Am I missing something, or is it not possible to rotate symbols
>> based on a rotation attribute when using the rule based renderer?
>> Maybe I don't find it in the GUI? Or is this very important feature
>> not yet present?
>> Thanks,
>> Andreas
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
