[Qgis-developer] Load Project file from plugin
Etienne Tourigny etourigny.dev at gmail.com
Mon Nov 19 08:31:20 PST 2012
To load a project file call QgisInterface::actionOpenProject()
most app-related stuff that a plugin can do are in the QgisInterface class
On a related note:
If you want the plugin to do something when a project file is loaded,
you need to connect to the QGisInterface projectRead() signal
http://www.qgis.org/api/classQgisInterface.html#af740dfa32487613224a249c8f5c2111b
This will ensure that when a project is loaded your code will get called.
On Mon, Nov 19, 2012 at 2:12 PM, Justin Hubbard
<justin at pyrotechsoftware.com> wrote:
> Hi
> I must be missing something... I have searched the API and the web, but
> cannot find out how to do this seemingly simple task
> I want to make my plugin automatically load a specified .qgs Project file
> into QGIS when the plugin is activated.
> I'm sure that I must be missing something.
> Any help appreciated
> Thanks
> Justin
> Qgis-developer mailing list
