[Qgis-developer] Load Project file from plugin
Tim Sutton
lists at linfiniti.com
Mon Nov 19 12:09:07 PST 2012
Hi
On Mon, Nov 19, 2012 at 6:31 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> To load a project file call QgisInterface::actionOpenProject()
Or programmatically open the project file like this:
QgsProject.instance().setFileName(myProjectPath)
QgsProject.instance().read()
Regards
Tim
> most app-related stuff that a plugin can do are in the QgisInterface class
> On a related note:
> If you want the plugin to do something when a project file is loaded,
> you need to connect to the QGisInterface projectRead() signal
> http://www.qgis.org/api/classQgisInterface.html#af740dfa32487613224a249c8f5c2111b
> This will ensure that when a project is loaded your code will get called.
> On Mon, Nov 19, 2012 at 2:12 PM, Justin Hubbard
> <justin at pyrotechsoftware.com> wrote:
> > Hi
> > I must be missing something... I have searched the API and the web, but
> > cannot find out how to do this seemingly simple task
> > I want to make my plugin automatically load a specified .qgs Project file
> > into QGIS when the plugin is activated.
> > I'm sure that I must be missing something.
> > Any help appreciated
> > Thanks
> > Justin
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
