[Qgis-developer] Load Project file from plugin
G. Allegri
giohappy at gmail.com
Mon Nov 19 12:13:48 PST 2012
It could be useful (for the future) to have also a writtenProject signal,
to be able to do post-saving processing. I will add a wish ticket...
giovanni
Sent from Nexus
Il giorno 19/nov/2012 21:09, "Tim Sutton" <lists at linfiniti.com> ha scritto:
> Hi
> On Mon, Nov 19, 2012 at 6:31 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
> > To load a project file call QgisInterface::actionOpenProject()
> Or programmatically open the project file like this:
> QgsProject.instance().setFileName(myProjectPath)
> QgsProject.instance().read()
> Regards
> Tim
> > most app-related stuff that a plugin can do are in the QgisInterface
> class
> > On a related note:
> > If you want the plugin to do something when a project file is loaded,
> > you need to connect to the QGisInterface projectRead() signal
> http://www.qgis.org/api/classQgisInterface.html#af740dfa32487613224a249c8f5c2111b
> > This will ensure that when a project is loaded your code will get called.
> > On Mon, Nov 19, 2012 at 2:12 PM, Justin Hubbard
> > <justin at pyrotechsoftware.com> wrote:
> > > Hi
> > > I must be missing something... I have searched the API and the web, but
> > > cannot find out how to do this seemingly simple task
> > > I want to make my plugin automatically load a specified .qgs Project
> file
> > > into QGIS when the plugin is activated.
> > > I'm sure that I must be missing something.
> > > Any help appreciated
> > > Thanks
> > > Justin
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121119/e810c31c/attachment.html>
