[Qgis-developer] Load Project file from plugin
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 19 12:27:25 PST 2012
It seems to me that QgisInterface::actionOpenProject() (and
QgisApp::addProject()) do a lot more than QgsProject.instance().read()
- how much of that is important?
Etienne
On Mon, Nov 19, 2012 at 6:09 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Mon, Nov 19, 2012 at 6:31 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> To load a project file call QgisInterface::actionOpenProject()
> Or programmatically open the project file like this:
> QgsProject.instance().setFileName(myProjectPath)
> Regards
> Tim
>> most app-related stuff that a plugin can do are in the QgisInterface class
>> On a related note:
>> If you want the plugin to do something when a project file is loaded,
>> you need to connect to the QGisInterface projectRead() signal
>> http://www.qgis.org/api/classQgisInterface.html#af740dfa32487613224a249c8f5c2111b
>> This will ensure that when a project is loaded your code will get called.
>> On Mon, Nov 19, 2012 at 2:12 PM, Justin Hubbard
>> <justin at pyrotechsoftware.com> wrote:
>> > Hi
>> > I must be missing something... I have searched the API and the web, but
>> > cannot find out how to do this seemingly simple task
>> > I want to make my plugin automatically load a specified .qgs Project file
>> > into QGIS when the plugin is activated.
>> > I'm sure that I must be missing something.
>> > Any help appreciated
>> > Thanks
>> > Justin
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
