[Qgis-developer] how to run a single python test from source directory?
Tim Sutton lists at linfiniti.com
Tue Nov 20 12:57:45 PST 2012
Hi
On Tue, Nov 20, 2012 at 6:27 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> thanks
> I just discovered that "make test" calls ctest, and ARGS value is
> passed to ctest.
> To get verbose output (like debug messages and any print you do in the
> tests), you need to add the -V option
> i.e.  ARGS="-V -R PyQgsVectorLayer" make test
Alternatively you can do:
ctest -R PyQgsVectorLayer -V
Regards
Tim
> On Tue, Nov 20, 2012 at 1:59 PM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Etienne,
>> On Tue, 20. Nov 2012 at 13:44:34 -0200, Etienne Tourigny wrote:
>>> I can get the python tests to run using "make test" from the build dir
>>> - but that is very long as it does ALL tests
>> Try
>> ARGS="-R PyQgsVectorLayer" make test
>> See also:
>> http://lists.osgeo.org/pipermail/qgis-developer/2012-September/022062.html ;)
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>> Software Engineer         D-26506 Norden               http://www.norbit.de
>> committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
