[Qgis-developer] Adding a project as a reference
Andreas Neumann
a.neumann at carto.net
Mon Nov 26 23:40:43 PST 2012
Hi Denis,
We have the embedded layers and groups. You can select another QGIS
project and pick the groups and layers you want. It is a live link. I
use this feature to integrate the cadastral data in pretty much any of
my other projects.
It does not allow to change any settings on the layers (e.g. different
min/max scales) - but other than that it works great.
Did you have a look at this feature?
Andreas
On Tue, 27 Nov 2012 08:34:54 +0100, Denis Rouzaud wrote:
> Hi all,
> I don't know if this idea has been raised or not, a quick google
> search did not lead to anything.
> I wonder if it would be feasible to introduce the option of adding a
> project as a reference, as you can do in autocad.
> Basically, this would be a new type of layer, where you could specify
> the scale visibility for example. Layers do not need to be editable
> and they shouldn't.
> The advantage is that you can insert a "base" project into many
> children project. The base layers will be regrouped into one.
> Anybody ever thought about this?
> Do you have any idea of the amount of work?
> Thanks a lot
> Denis
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
