[Qgis-developer] Adding a project as a reference
Denis Rouzaud denis.rouzaud at gmail.com
Tue Nov 27 00:52:28 PST 2012
Hi Andreas,
Thanks for the reply.
I did not know this feature, which is basically what I asked ;) Great!
I am just facing a few problems. When adding a group, a box appears with
std::bad_alloc and qgis crashes a few times (both 1.8 and master).
Also, not all the layers I select are loaded.
Any ideas on something wrong?
Thanks again,
Denis
On 11/27/2012 08:40 AM, Andreas Neumann wrote:
> Hi Denis,
> We have the embedded layers and groups. You can select another QGIS
> project and pick the groups and layers you want. It is a live link. I
> use this feature to integrate the cadastral data in pretty much any of
> my other projects.
> It does not allow to change any settings on the layers (e.g. different
> min/max scales) - but other than that it works great.
> Did you have a look at this feature?
> Andreas
> On Tue, 27 Nov 2012 08:34:54 +0100, Denis Rouzaud wrote:
>> Hi all,
>> I don't know if this idea has been raised or not, a quick google
>> search did not lead to anything.
>> I wonder if it would be feasible to introduce the option of adding a
>> project as a reference, as you can do in autocad.
>> Basically, this would be a new type of layer, where you could specify
>> the scale visibility for example. Layers do not need to be editable
>> and they shouldn't.
>> The advantage is that you can insert a "base" project into many
>> children project. The base layers will be regrouped into one.
>> Anybody ever thought about this?
>> Do you have any idea of the amount of work?
>> Thanks a lot
>> Denis
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
