[Qgis-developer] Adding a project as a reference
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Nov 27 00:55:18 PST 2012
Hi Denis
>a box appears with std::bad_alloc and qgis crashes a few times (both
1.8 and master).
Could you open a ticket in the bugtracker and add a small sample project?
Regards,
Marco
On 27.11.2012 09:52, Denis Rouzaud wrote:
> Hi Andreas,
> Thanks for the reply.
> I did not know this feature, which is basically what I asked ;) Great!
> I am just facing a few problems. When adding a group, a box appears
> with std::bad_alloc and qgis crashes a few times (both 1.8 and master).
> Also, not all the layers I select are loaded.
> Any ideas on something wrong?
> Thanks again,
> Denis
> On 11/27/2012 08:40 AM, Andreas Neumann wrote:
>> Hi Denis,
>> We have the embedded layers and groups. You can select another QGIS
>> project and pick the groups and layers you want. It is a live link. I
>> use this feature to integrate the cadastral data in pretty much any
>> of my other projects.
>> It does not allow to change any settings on the layers (e.g.
>> different min/max scales) - but other than that it works great.
>> Did you have a look at this feature?
>> Andreas
>> On Tue, 27 Nov 2012 08:34:54 +0100, Denis Rouzaud wrote:
>>> Hi all,
>>> I don't know if this idea has been raised or not, a quick google
>>> search did not lead to anything.
>>> I wonder if it would be feasible to introduce the option of adding a
>>> project as a reference, as you can do in autocad.
>>> Basically, this would be a new type of layer, where you could specify
>>> the scale visibility for example. Layers do not need to be editable
>>> and they shouldn't.
>>> The advantage is that you can insert a "base" project into many
>>> children project. The base layers will be regrouped into one.
>>> Anybody ever thought about this?
>>> Do you have any idea of the amount of work?
>>> Thanks a lot
>>> Denis
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
