[Qgis-developer] Html image map plugin error
Richard Duivenvoorde rdmailings at duif.net
Tue Nov 27 13:57:43 PST 2012
On 11/27/2012 02:17 PM, Paolo Cavallini wrote:
> "/home/paolo/.qgis//python/plugins/imagemap_plugin/imagemapplugin.py",
> line 322, in ring2area
>      htm.remove(len(htm)-1,len(htm))
> AttributeError: 'unicode' object has no attribute 'remove'
> Anyone confirms?
> All the best.
Hi Paolo,
Thanks for the report, but I cannot confirm this either.
Can you maybe sent me the data you are using, or more information about
the type of geometries you are using as the output layer?
Or maybe you have some special characters in filename or attributes or so?
You are not using Python 3 are you?
Regards,
