[Qgis-developer] Get rid of Shapefiles ! Go SpatiaLite !
Andrea Peri aperi2007 at gmail.com
Tue Nov 27 09:37:19 PST 2012
>Hi Stefan,
>I think QGIS users are more likely to seek interoperability with other systems than ESRI users. So making ESRI work with QGIS via SpatialLite is probably not something that offers ESRI >users much benefit, they'll probably be using ESRI file geodatabases instead.
>I believe QGIS will achieve more traction by working well with Arc,and seamlessly within an Arc environment, than the other way around. So while I have no problem with enhanced support for >SpatiaLite for QGIS (& Arc), this should not be at the expense of shapefile support.
Try-ing to supporto esri arcgis will introduce other and bigger problems.
We have many trouble due to the convention of esri for the hole that
are touching the boundary of a polygon.
The esri product will trasform this in a not OGC compatibile structure.
That on a OGC system is defined Invalid.
So when a dataset with hole is touched from a esri arcgis it could
became invalid for OGC.
This is so a problem for us that we fund a change to postgis to have a
ST_IsValid with a flag for compatibily with esri gemetries.
QGIS is absolutely unuseful try to follow Arcgis if QGIS himself also
don't support this different structure of polygons with hole on
boundaries.
Regards,
Andrea Peri
qwerty àèìòù
