[Qgis-developer] QGIS python plugin, segmentation fault, what can I do?
Dominik Fröhlich dominik.froehlich at venus.uni-freiburg.de
Thu Oct 4 07:05:31 PDT 2012
Hello,
I'm trying to write a python plugin to create an input file for an urban
climate model (RayMan) out of three shape files.
Unfortunatelly QGIS closes when I try to load the plugin (Windows, as
well as Linux, both 32bit, version 1.8.0). When I start QGIS from the
Terminal (Ubuntu), I get "segmentation fault" when it happens. Thats all.
Is there some function that is known to crash QGIS or do you have any
suggestions how I could  track down the error?
I put the plugin on our server if that helps. It can be downloaded from
http://www.urbanclimate.net/shp_to_obs.zip.
Best regards!
Dominik Froehlich
