[Qgis-developer] License Summary
Werner Macho
werner.macho at gmail.com
Fri Oct 5 14:51:52 PDT 2012
Thanks to the fine script from Jürgen and hist help I can say we are now
down to about
186 Files having in UNKNOWN license out of 2073 files which should have
a license
I've seen there are a some in
GdalTools
db_manager
some in the scripts directory itself
grass
and some in the tests subdirectory
and then there are some which license unfortunately is not getting
recognised by the licensechecker and mistakenly set as "UNKNOWN"
but at least I see a huge progress in having lesser not licensed files
in the source tree ..
if you have time please have a look through your files and add a proper
header
thanks a lot
Werner
On 10/04/2012 04:00 PM, Victor Olaya wrote:
>>> I don't see why sextante in qgis has to change from MIT to GPL, does
>>> it really have to?
>>> No, it does not have to, from a legal point of view.
>> I do not think it has changed: java and python versions have no code in
>> common, so the author simply chose a different licence.
>> All the best.
> Just to make clear. I prefer the MIT license in the case of the Java
> version, as it is meant to be used in many different apps (it is a
> library). I the python case, it is just a QGIS plugin, so I do not see
> much difference and i am happy with GPL as well. I think is a better
> idea, so as to have a homogeneous licensing across QGIS code.
> Regards
> Qgis-developer mailing list
