[Qgis-developer] testing core python plugins from build tree
Giuseppe Sucameli brush.tyler at gmail.com
Mon Oct 8 08:16:29 PDT 2012
On Mon, Oct 8, 2012 at 5:14 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Oct 08, 2012 at 05:11:21PM +0200, Sandro Santilli wrote:
>> On Mon, Oct 08, 2012 at 06:08:04PM +0300, Alexander Bruy wrote:
>> > But it is still possible to symlink core plugin dir to ~/.qgis/python/plugins/
>> > create temporary makefile to compile ui and start hacking.
>> "create temporary makefile" doesn't seem that straightforward, but
>> sounds like the shortest path. Hopefully I can just symlink the Makefile
>> in the build tree...
> Well, it wasn't enough:
>   ImportError: No module named ui_DlgDbError
which makefile are you using?
> at this point I'm not even sure db_manager is supposed to work
> even after install. Giuseppe, does it ?
> --strk;
Giuseppe Sucameli
