[Qgis-developer] testing core python plugins from build tree
Sandro Santilli
strk at keybit.net
Mon Oct 8 08:52:39 PDT 2012
On Mon, Oct 08, 2012 at 05:16:29PM +0200, Giuseppe Sucameli wrote:
> On Mon, Oct 8, 2012 at 5:14 PM, Sandro Santilli <strk at keybit.net> wrote:
> > On Mon, Oct 08, 2012 at 05:11:21PM +0200, Sandro Santilli wrote:
> >> On Mon, Oct 08, 2012 at 06:08:04PM +0300, Alexander Bruy wrote:
> >> > But it is still possible to symlink core plugin dir to ~/.qgis/python/plugins/
> >> > create temporary makefile to compile ui and start hacking.
> >> "create temporary makefile" doesn't seem that straightforward, but
> >> sounds like the shortest path. Hopefully I can just symlink the Makefile
> >> in the build tree...
> > Well, it wasn't enough:
> > ImportError: No module named ui_DlgDbError
> which makefile are you using?
Makefile -> ../../../b/python/plugins/db_manager/Makefile
Where ../../../b is my build tree, so the Makefile generated
by cmake.
--strk;
